You're Right
A. Bohemian
06-28-2007 17:49:23
Quote: " I get a steady drip, but I would think it would be more of a steady flow."
This is a gravity feed system. As such there are two primary limiting factors to gas flow; the amount in the tank and the diameter of the line.
A stream significantly smaller than the diameter of the line indicates blockage. It could be the screen in the tank or the one in the shut-off/sediment bowl assembly or the one in the elbow of the line is clogged, or the line itself is clogged.
What does the sediment bowl look like? Fine rust particals often mean larger particles elsewhere in the system. You can also look around inside the tank for visable rust; a flash light and a dentist's mirror can help here.
