This Looks Like a Job For Dashboard Ammeterman!
A. Bohemian
07-04-2007 13:52:04
Quote: ''How do I tell if the coil is bad or the points are bad?''
The only way I know of to tell if a coil is bad is to replace it. Do try stretching the pigtail a bit and see if that helps; but other than that, it's hard to find most coil problems with a test light or voltmeter.
You can do voltage and resistance readings on the coil, but except for continuity (showing a complete open or a dead short), these won't tell you much. This is because they are static readings (ignition system not operating); and the coil usually fails due to breakdown of the insulation between windings, which occurs only when there is high voltage across the secondary of the coil, which occurs only when the ignition system is operating (dynamic).
Ah, but the points. The points...
Look at your dashboard ammeter with the ignition on but without cranking the motor. You should show an approximate three-amp discharge.
No discharge? The points are not closing or not making good contact, or there is an open elsewhere in the system.
Normal discharge? Crank the engine. You should see the ammeter fluctuate as the points open and close. No fluctuation? The points are likely shorted, not opening for some reason, or there is a short elsewhere in the system.
Ammeter behaving normally? Now is the time to consider trying another coil.
stryped
07-04-2007 13:56:14
 Re: This Looks Like a Job For Dashboard Ammeterman! in reply to A. Bohemian, 07-04-2007 13:52:04
When I replaced the key switch about 7 months ago I must have done somethign wrong. The ammeter has not worked since.
A. Bohemian
07-04-2007 14:12:16
 I'd Fix it. in reply to stryped, 07-04-2007 13:56:14
It is just barely remotely possible that the wiring mistake you made when you wired in the new switch has something to do with the reason your tractor won't start. Figure out what you did wrong and wire it up right.
And anyway, trying to maintain a Kettering ignition without an ammeter is like making bricks without straw (Exodus 5:8-23).
stryped
07-05-2007 05:45:49
 Re: I'd Fix it. in reply to A. Bohemian, 07-04-2007 14:12:16
It has run many months without problems since the new switch.
Where can I find a new wiring diagram to make sure everythign is wired correctly?
