I'd Fix it.
A. Bohemian
07-04-2007 14:12:16
It is just barely remotely possible that the wiring mistake you made when you wired in the new switch has something to do with the reason your tractor won't start. Figure out what you did wrong and wire it up right.
And anyway, trying to maintain a Kettering ignition without an ammeter is like making bricks without straw (Exodus 5:8-23).
stryped
07-05-2007 05:45:49
 Re: I'd Fix it. in reply to A. Bohemian, 07-04-2007 14:12:16
It has run many months without problems since the new switch.
Where can I find a new wiring diagram to make sure everythign is wired correctly?
