Bad Gasket? Yep.
A. Bohemian
08-06-2007 13:35:23
Quote: ''I looked at it and when i opened the radiator cap, all that is in there is motor oil. The owners says its a bad head gasket...''
What you saw no doubt looked like motor oil; but it may well have been combustion products suspended in the coolant. This is indicative of a bad gasket and implies the owner is at least being honest with you about that.
Indiana Jones has an important point about that oil. Oftentimes a head gasket on a flat-head will blow with no lasting effects; but IF water did get in the oil and IF the tractor was run with water in the oil this one is potentially a rebuild candidate.
