Your Dashboard Ammeter Tells All!
A. Bohemian
08-23-2007 18:36:02
What does your dashboard ammeter say?
Turn on the ignition without cranking. You should see a static discharge of three amps or so.
No discharge? The points are not closing correctly, are not conducting properly, or there is an open somewhere else in the system, like the coil primary. (Likely it's the points.)
Normal discharge? Crank the engine with the ignition on. You should see the ammeter dip or flutter as the points open and close.
No dip or flutter? The points are not opening, are shorted, or there is a short elswhere in the system. (Again, the points are the chief suspect.)
