It's Called the Weaksister For a Reason
A. Bohemian
08-28-2007 09:46:40
These switches fail so often that some mechanics routinely replace them as a FIRST STEP in troubleshooting a problem like yours!
You cannot test them reliably with a voltmeter or test light because these test only STATIC (engine not running) performance, and sometimes the ignition switch fails under DYNAMIC (engine running and ignition system cycling away) conditions.
You CAN put a jumper across the terminals, which will isolate failure of the switch contacts to properly conduct direct current, but will NOT isolate problems with the switch arcing to ground due to cracked/dirty insulation.
A search of these boards with the words ''weaksister'' and ''ignition'' will no doubt tell you much, much more.
