Yes.
A. Bohemian
08-29-2007 14:58:18
Quote: ''A.Bohem made mention of how much energy the ignition disipated. that would take into account any series primary resistances AND the coil.. not just the coil.''
Quite right. I was thinking of the SYSTEM current which is of course displayed by the ammeter, including the ballast resistor.
To approach the same question from a different angle, what does a dashboard ammeter read with a correctly designed twelve-volt conversion?
soundguy
08-30-2007 06:35:47
 Re: Yes. in reply to A. Bohemian, 08-29-2007 14:58:18
As OK aluded to... E=IR is going to be the main determining factor of what the ammeter reads. The points will still be a 'waek link' in that they won't like to see much more than 3-4a
Couple that with a non precision ammeter movement.. and it's gonne be hard to tell if your ammeter is reading between 1.5-4a in most cases... especially the old loop meters..e tc.
All said.. your choice of coil and any resistors inline, and condition of all electrical connections, exact votlage of the charge system, etc.. all those will be variables for the ohms law equation.. etc.
Soundguy
OKDAD
08-29-2007 23:23:43
Hi Bohemian,
You pose an interesting question but I have one for you...Can you define "A correctly designed 12 volt system"?
The current draw by the ignition system is dictated by the battery voltage divided by the resistance of the coil, ballast resistor(s), wiring, and electrical connections. If you double the battery voltage then the resistance will need to double to keep the voltage constant thru the coil. This is why most 12v systems add another ballast resistor. The current draw shown on the meter would be the same.
Ike
