More Than One
A. Bohemian
09-05-2007 15:35:56
If it was truly hitting on only one cylinder, the engine probably would not run. The Ford flathead four (and most other simple four cylinder engines) will generally run on two cylinders, but not on only one.
I think soundguy is probably right here; check the firing order. 1-2-4-3 with number one at the FRONT.
A. Bohemian
09-05-2007 15:44:25
 Word Trouble in reply to A. Bohemian, 09-05-2007 15:35:56
Sorry. I meant, "The Ford flat-head four will run on two cylinders, but generally won't run on only one."
