ammeter
roger '40 9n
09-11-2007 18:06:39
The N tractors did not come from the factory with an altimeter. Ammeters were standard tho.
Yours sound like it is working normally. Ammeter shows net charge into or outa the battery. Near zero is correct after replacing current lost from running the starter motor.
roger in michigan
Jim.UT
09-12-2007 14:30:23
 Re: ammeter in reply to roger '40 9n, 09-11-2007 18:06:39
I got an altimeter in my truck. It's just a cheapie and is highly affected by the weather, but it's fun to watch it go from 5400 to just over 7000 then back down to 4200 when I go to Salt Lake (50 miles). I find it interesting to monitor on longer trips, too.
When I drove to the east coast back in '97 it was pretty boring after Denver....it didn't seem to move much!
Ross Pugh(NC)
09-12-2007 16:08:04
 Re: ammeter in reply to Jim.UT, 09-12-2007 14:30:23
Hey, you guys, an altimeter, tells you at what altitude you are flying on an airplane. On your truck it would tell how high above sea level you are. That thing on yer truck that moves the hand when you rev the engine is a tachometer that tells the rpm's your engine is turning. The ammeter shows charging or discharging of the alternator. Once the battery is charge fully it will level out at zero.
Jim.UT
09-12-2007 22:05:38
 Re: ammeter in reply to Ross Pugh(NC), 09-12-2007 16:08:04
I know what an altimeter is. When I leave home I'm at 5400 feet above sea level. On my way to SLC I go up to 7000 feet twice then down to 4200 feet.
