Order Ford 8N Parts Online
Re: 8n no fuel to plugs
Colin King
01-31-2008 13:29:09
What are your compression numbers? Generally it seems that anything below 90psi on all 4, you"re going to have a lot of trouble starting.
Have you done a wet and dry compression test?
How do you know you"re not getting fuel into the cylinder? Have you tried starting it, then pulled a plug to see if it was wet/smelled of gas?
Have you tried replacing the plugs with new ones? Autolite 437s gapped 0.025. These engines are easy to flood, and flooded plugs don"t fire as hot.
Colin, MN
