Order Ford 8N Parts Online
Re: Testing a Coil for 8N
MikeT
02-12-2008 07:41:20
third party image
This aught to work as an initial test of a coil. When you rapidly touch and release the wire to the negative post of the battery you should see a hot blue spark at the plug gap. Don't leave the wire connected else you might melt the coil.
This test would only show you that the wiring inside the coil is intact. Would not tell you if the coil is putting out recommended voltage.
