You be the judge
TheOldHokie
03-28-2008 14:20:52
9N again said: (quoted from post at 13:39:49 03/28/08) Howdy Y'all
You all seem to know somthing about everything so I will ask. I have a troy built roto tiller and they say for the gear oil to only use GL4 140 or 85w-140, i cant find GL4 anywhere but i can find GL5. Will this work. Any ideas.
Thanks
You be the judge:
API Gear Oil Service Designations (PDF)
To summarize those 12 pages the central difference between GL4 and GL5 service designation is that GL4 designation indicates a lubricant has anti-wear additives suitable for use with spiral bevel and hypoid gearsets operating under mild to moderate loads and speeds. GL5 designation indicates a lubricant with additional additives for use with spiral bevel and/or hypoid gearing operatiing under severe loads and at high speeds.
What's in your Troybilt ;-)
TOH
TheOldHokie
03-28-2008 14:27:52
 PS in reply to TheOldHokie, 03-28-2008 14:20:52
By the way that document is dated 1995 and notes that some test equipment needed to test for GL4 compliance is no longer available - perhaps why the designation is getting harder to find - manufacturer's are just skipping GL4 in favor of GL5.
