FLUIDS
ron Tron
05-20-2008 07:32:13
had my 9N for years and never thought about adding any thing different to the box than hydraulic fluid and someone recently said I need to blend 90 weight gear oil with hydraulic fluid..... ....what do you chat room experts say.?
Mike OH
05-20-2008 08:09:08
 Re: FLUIDS in reply to ron Tron, 05-20-2008 07:32:13
If you are referring to the oil used in the transmission, rear end, and lift then I think I would NOT try to re-engineer what the design engineers established years ago; or what THEY recommend to use today. Using non recommended products (by the manufacturer) can sometimes lead to problems if the products are not compatible with each other. Oh, and by the way, I'm not an expert, but that is my opinion.
Bruce (VA)
05-20-2008 08:05:43
The link below might help
