Lesser Known Classics Discussion Forum
SKF throw out bearings near that size:
Bob
11-09-2006 07:08:16
# N3066 I.D. 1.4990" O.D. 2.6415" Thick .6190"
# N3055 I.D. 1.4995" O.D. 2.5130" Thick .6490"
# N3042 I.D. 1.5000" O.D. 2.6902" Thick .7728"
# N3043 I.D. 1.5000" O.D. 2.6902" Thick .7728"
# N1054 I.D. 1.5000" O.D. 2.8300" Thick .6820"
# N4006 I.D. 1.5200" O.D. 2.4850" Thick .5750"
Are any of these close enough to work?
It looks like the N3066 is pretty close, but a little larger on the O.D. According to the diagram, that is the MAXIMUM overall ID of the bearing, measured at the "crimp", behind the front face. Are you measuring the front face, or the overall I.D. of the crimped area?
Let me know what you figure out!
tractor-ernie
11-17-2006 08:53:47
 Re: SKF throw out bearings near that size: in reply to Bob, 11-09-2006 07:08:16
I have the exact measurements of the collar and spline. The spline that goes through the bearing is 1.55 in od. The collar is 2.59 in id. Do you have anything about that size? Thanks
tractor-ernie
11-17-2006 08:53:22
Bob
11-19-2006 23:44:35
 Let's try this again... in reply to tractor-ernie, 11-17-2006 08:53:22
You need JUST the throwout bearing, correct, and not the "carrier" inside the bearing that slides or the tranny input "snout" (or equivalvent)?
What is the correct ID of the bearing?
What is the correct OD of the bearing?
What is the correct thickness of the bearing?
(I'm not understanding what the measurement of the splines has to do with anything, as the bearing slides on the "tranny snout", rather than the pilot shaft splines, correct???)
Get back to me with those measurements, and I'll take another "stab" at it!
tractor-ernie
11-20-2006 08:05:14
 Re: Let's try this again... in reply to Bob, 11-19-2006 23:44:35
I have the collar in which the bearing fits. I am not measuring the old bearing becaase its very worn and has welds all over it. The collar seat (in which the bearing sits) is 2.59 id. I understand that the bearing should fit snuggly into that space. Then the collar with the bearing slides over the shaft (spline) that goes to the transmission. That shaft is 1.55 od. The old bearing that is really worn is .62 in. wide.
Bob
11-20-2006 22:12:57
 Re: Let's try this again... in reply to tractor-ernie, 11-20-2006 08:05:14
Ernie,
I sounds like that unit is made backwards of conventional throwout bearings.
Any chance you could post a picture, or email me a picture of the unit?
bigcoulee@hotmail.com
