Lesser Known Classics Discussion Forum
Transmission shaft and clutch?
bjr
08-23-2007 08:14:57
I agree with others on using the 3208 for the correct RPM's and power the thing I'm not sure of is getting the flywheel and bell housing size to match the tran. input shaft. Are there different input shafts for that transmission available? Different engine applications take different governor types. Get the correct style of governor for you tractor. For example the cummins truck fuel pump wouldn't be correct as you would need a VS (variable speed) and these can get spendy, just be aware. Engine swaps can be a nightmare, so do your homework first, you'll be glad you did. bjr
