CNKS
07-02-2006 18:28:06
Re: No! in reply to Rod (NH), 07-02-2006 16:09:40
Rod and B -- Check the link -- In the diagram, the filter/whatever I am using is the 6950, click on the top right in the diagram. I had not seen this site before. I notice that it is for air tools, not for painting, but it has 1 micron filtering capacity. The ones for paint booths are two stage. Of course the diagram with all the filters/traps is for commercial people, not the one size fits all I am looking for. So, I don't know if the 6950 I have traps anything but water or not. I stripped the threads on my oldest filter, the one closest to the compressor, will have to replace the canister, so I took it apart. It consists of fabric webbing on one end and wire mesh webbing on the other. Slightly stained, not really dirty. I also tore apart the filter on the gun, just a stack of paper washers, absolutely clean and dry. I am leaning toward getting a Sharpe or other 2,3 stage, since RTI does not recommend the one I have for paint. However the owner of the business I bought it from sells a lot of them for painting, and is a painter himself -- so I do not know. With your and B's opposition to the line change (I liked your NO!), I am pretty much convinced that the lines are not the problem. I looked at a couple of parts I painted Friday, they aren't that bad, maybe I'm too picky. But, I would like to paint something and not get those bumps or needle points, or solvent pop, or whatever it is.
