etch
Circus
03-16-2007 07:01:49
Sandblasting works but can warp thin steel. Light rust should be sanded then acid etched. Milking equipment acid rinse (posphoric acid)is a cheap alternative to the autobody stuff. Drape paper towel over the rust, soak it with the acid, wait, rinse with water and scuff.
Gil Sykes
03-16-2007 14:51:12
 Re: etch in reply to Circus, 03-16-2007 07:01:49
Does this stop the rust. This is new to me but I am willing to give it a try. I have a sand blaster but I haven"t used much. Thanks for the info. I would like to know if the 8n fenders will work on ford 600. I am re working a 600 and I would like it back as near original as possible. Gil
circus
03-17-2007 06:18:13
 Re: etch in reply to Gil Sykes, 03-16-2007 14:51:12
Etching leaves no protection. At least the way I use it. Rinsing it off prior to drying.
circus
03-17-2007 05:48:39
Use paper towel only if its really rusty. Etching will remove the rust from the pits and pores but leaves no protection. After water rinse the whole piece will have a haze of rust that's easily scuffed off with sandpaper or scotch bright pad. It will rust fast so coat it with something.
