What about Clear for over the paint job??
Larry59
04-02-2008 20:25:33
Will clear give me that real nice shine look to the paint? I have a case 311-B tractor. It's called the general size and not the ut small tractor. So how much clear would one use? How many coats of this clear would be proper? THanks
glennster
04-03-2008 14:40:42
 Re: What about Clear for over the paint job?? in reply to Larry59, 04-02-2008 20:25:33
larry , i assume you are using a single stage paint, if you want to clear it, you will need a clear that is compatible with your base coat. as far as getting a good shine to your paint, it can be done with a single stage and no clear. generally the last color coat needs to go on wet so it lays nice, then if you want more shine, you need to wetsand and buff the paint after it drys.
patsdeere
04-03-2008 07:16:37
I have never used clear on a tractor so I have no clue how much it uses. If you search through the board you will find some other posts about clear.
