Re: Re: spray guns
CNKS
12-17-2003 13:25:41
You are correct that the primary function of different tip sizes is to match the viscosity of the paint, but tip size DOES affect pattern size and the speed at which you move the gun. The guns are designed to work best at full pattern, which is why I have a couple of tips for the same viscosity paint. Compressor size is either the same as or greater than that required for conventional guns, depending on the air requirement of the gun itself. With a good filter system water is not a problem. My outlet is about 70 feet from the compressor and my $125 filter works fine. I also drain the tank daily and have a means of draining the lines also. Turbine HVLP is fine, I just don't need a dedicated system. If I spent most of my time painting, I would certainly consider one.
