Re: Primer vs Pirmer/surfacer
CNKS
08-05-2004 18:42:55
Checked the P-Sheet on 181 -- it doesn't list color. Since I had never used it I assumed it was red since the same spec sheet lists MP281 as light gray, but obviously it is dark gray as you say. As to 182, it is a darker shade than 170, perhaps I was seeing 170. Seems most of the scratches (not many anyway) have been on the cast, since I am very careful with the tin, since touch-ups show more on the smooth surface. I have tinted 182, mostly to see if I was sanding down to the untinted color, sort of like a guide coat. Actually, I like the contrast in color over the epoxy or surfacer, because I can see if I am getting good coverage.
