PPG/OMNI Paint code for Oliver Hart-Parr 70
Travis M
11-24-2004 18:08:30
I am trying to cross the paint code for my hart parr 70"s dark green paint to a PPG # but I am having a hard time doing so. It is darker than the normal "OLiver" green. I found it in the DAR line of PPG but this is not being made -so I have been told. I would like to find a number for PPg"s OMNI MBC or the DBU could cross also. Any help would be appreciated.
Rod (NH)
11-24-2004 19:38:12
 Re: PPG/OMNI Paint code for Oliver Hart-Parr 70 in reply to Travis M, 11-24-2004 18:08:30
Hi Travis,
If you have a PPG DAR number that you are sure you want, just use the same number in the PPG OMNI line. For example, using Oliver standard green (40812):
DAR40812 = DAR Acrylic Enamel
MAE40812 = OMNI Acrylic Enamel
MTK40812 = OMNI Acrylic Urethane (single stage)
MBC40812 = OMNI Acrylic Basecoat
DBU40812 = DBU Deltron Basecoat
These are all the same color. The basecoats of course require a clear coat on top. The DBU would be significantly more expensive than the MBC. Not worth it in my opinion unless you are panel matching an existing automotive color. For overalls, you would not notice the difference. The MBC will take an extra coat compared with the DBU. If you are interested in my own detailed cost comparison of MBC/DBU, see this thread.
Like you, I cannot get the Delstar DAR locally at all. I understand it is available in some parts of the country. You can also get it mail-order, I guess, from here - that is if you want to pay the rather high price. I am assuming that the appropriate reducers and hardener are also available from the same seller but they don't seem to list them on their site. DAR is an excellent acrylic enamel but not worth the current high price, IMO, when the OMNI MAE and MTK is more readily available at a much lower cost.
third party image Rod
Travis M
11-25-2004 05:53:36
 Re: PPG/OMNI Paint code for Oliver Hart-Parr 70 in reply to Rod (NH), 11-24-2004 19:38:12
Thank you Rod! I was still deciding on whether to go with the DBU or the MBC-you have made my mind up to go with the MBC. One other question for you... i see there are several differant clear from OMNI-like,MC 260 quick clear, MC 161 high solids Urethane clear, or SV MC262 2.1 Clear. Do you have a favorite out of these? Or is one better than the other?Thanks again, Travis
Rod (NH)
11-25-2004 16:58:38
 Re: PPG/OMNI Paint code for Oliver Hart-Parr 70 in reply to Travis M, 11-25-2004 05:53:36
Travis,
I have only used the MC161 so I can't compare the other two. I have been perfectly satisfied with the 161. While not needed for gloss over a single stage paint, I have used it to clear over decals on MTK on my AC-B. I think that tends to blend the sharp edges of vinyl cut decals and gives them a smoother, more painted on appearance. It also provides some protection to the decal itself.
Don't get me wrong on the MBC. The DBU is a higher-end, "better" paint if you will. That's why it costs more - no such thing as a free lunch. All the work I do is for myself and unfortunately, I have to make value decisions on costs and benefits. I cannot pass along costs to customers and from my limited bc/cc experience and purpose, I believe the significant extra cost for the DBU over the MBC is not worth it. That would not be the case if I were operating a body shop where time constraints and color matching OEM car/truck panels are prime considerations. Under that situation the DBU would be the choice.
The OMNI line is not a high-end paint line and is not intended to be. However, I have found it to be quite satisfactory for my purposes and believe it provides a very good choice for a modern, durable paint at a reasonable price. I am not pushing only PPG here as I believe the similar economy lines in DuPont (NASON), Martin Senour and other big name paint manufacturers would provide similar value to tractor painters. I am not a brand basher as I think basic paint chemistry is a far more important criteria for paint selection than brand.
Rod
Felipe Penagos
03-12-2006 13:24:10
 Re: PPG/OMNI Paint code for Oliver Hart-Parr 70 in reply to Rod (NH), 11-25-2004 16:58:38
ROD, im just a 16-year old but i was wondering in the OMNI SV MC262, if that needed to be mixed with anything else or if it can just be put on straight from the can
