Frank
Tim...Ok
02-18-2005 04:49:03
Are you saying I should use that 12385 only,or should I use one from that line that fits my temp requirements?? I may try spraying a little this weekend,supposed to be pushing 70 degrees. Another question,Rod suggested thinning the PPG epoxy with up to 10% acetone for the final coat to use as sort of a sealer,the nason epoxy spec sheet doesn"t say anything about thinning,do you know of a compatible "thinner" for the Nason epoxy..Sorry for silly questions,I"m learning alot and new to this painting stuff :-)
Thanks,
Tim
Frank Stalfire
02-19-2005 07:01:11
 Re: Frank in reply to Tim...Ok, 02-18-2005 04:49:03
Sorry not to get back sooner, as for reducer use whatever temp range you like, what I meant was the nason is more of an economical line and part of the way to get prices down is to use more economical solvents, using Preimier solvents will give a more appealing final finish, it won't add dourability or anything like that. as for thinning epoxy, I don't really have any thouhgts on that since i have never tryed it,If Rod has tryed it and had sucess then he would be the man, just be sure whatever you do not to add to much because you will loose the characteristics of thre product
Tim...Ok
02-21-2005 05:15:08
 Re: Frank in reply to Frank Stalfire, 02-19-2005 07:01:11
Thanks Frank, I"ll give the Premier a try..
Tim
