CNKS
02-21-2005 06:54:36
Re: Update in reply to Rod (NH), 02-20-2005 21:14:04
Frank sent me that list, also, I have not fully digested it yet, as I hate to switch brands, since I like the way Omni works, nothing at all against DuPont, I simply have not used it. I don't paint enough to be able to make comparisons, I suppose I should get a pint of PPG and a pint of DuPont, see which I like, and make absolutely sure the next batch is mixed the same way under penalty of death or something (not really). It is my opinion, based on what I have read, and what others have told me that the "correct" IH 50 (light red) is PPG 70019/DuPont 7410, and that the IH 2150 (darker red) for later tractors is PPG 71310/DuPont 96766. To confuse the issue further 2150 did not replace 50, a similar color called 1102b did, and there was another color that I have seen in print only one time, I don't remember it. 2150 did not appear until the late 50's and was used I believe into the 80's or perhaps around the time that Tenneco aquired IH and merged it with Case. I have never heard of anyone having 1102b mixed, I haven't read Frank's info that close, I probably should. Biggest problem I have is getting the supplier to mix the paint right, and it now appears that there are so many variables that it may never happen, at least with my current dealer. I do get the grams printed out on the back of the label, I wish I had the other can back that I tossed a year or so ago. Thanks, I'm going to sort thru all your's and Frank's data before I buy any more paint, and try to make an approximately correct decision.
