Runs
Charles Park
08-05-2005 06:25:48
Okay, you are painting and then notice that you have a run in the job. Is there something you can do right then to correct this?
Ed in Maine
08-23-2005 14:08:30
 Re: Runs in reply to Charles Park, 08-05-2005 06:25:48
Neat link, looks like it would work good (if you take your time!, but then again if you do that you don't usually get runs!) ;-)
I try to put the air right to the run. If I only pull my trigger down half way, just air comes out. It at least blends it in a little and makes it look more like orange peel than a run.
Ed
Rod (NH)
08-09-2005 16:30:27
Today I ran across these specific instructions by Len Stuart on how to go about it.
Rod (NH)
08-05-2005 08:10:56
Unlikely. You'll just makes things worse if you try. If you didn't use a catalyzed paint (with hardener) then you probably have a significant problem that is not easily corrected - a lot depends on the actual paint and its recoat period. If you did use a hardener, then you might want to review my previously posted opinion on the matter in this thread.
