P.S.
Nicolas
11-01-2005 04:21:12
I see alot of good comments on here about epoxy primer, what should I use to thin it and how much? Thanks, Jdman
CNKS
11-01-2005 07:02:18
 Re: P.S. in reply to Nicolas, 11-01-2005 04:21:12
Basic rule -- If the paint does not come with instructions, don't buy it. If it does not say on the can, then ask the supplier for the instruction sheet, or go to the manufacturers web site. Epoxy primer is not usually thinned, and is two part, that is you add hardener according to the instructions. I know nothing about JD paint -- do what it says in the instructions.
Billy C.
11-01-2005 09:34:03
 Re: P.S. in reply to CNKS, 11-01-2005 07:02:18
The JD Classic Green that I bought but haven't used yet says mix one part thinner to 10 parts paint. I also bougt JD thinner.
