Re: Re: Re: will 15.5-38 tire fit on a rim that cu
2 cylinder
05-31-2003 07:01:11
If you reduce the air pressure on to narrow of a rim to much, the center of the tread will bow up and not make a good tread print on the ground. The best solution is a wider rim. It is also true that the 14.9 x 38 is more favorable to the 15.5 x 38.
