Re: Re: GOVENOR-CHADS
Flogger
02-20-2004 12:05:42
Hey Chad how will that spring work with a Thompson Rock-it governor? Any any gains at stock rpm? I can take the screw out and it won't turn but about 1800.
BUD BARENIE
02-20-2004 14:44:14
 Re: Re: Re: GOVENOR-CHADS in reply to Flogger, 02-20-2004 12:05:42
FLOGGER I'M USING AN M@W GOVENOR NOWSAME COPY AS THE ROCKET GOVENOR, GETTING READY TO THROUGHT IT AWAY !!!!
I'VE USED CHADS SPRING IT WILL BRING THE RPM'S UP
junkyard dog
02-20-2004 15:05:48
 Re: Re: Re: Re: GOVENOR-CHADS in reply to BUD BARENIE, 02-20-2004 14:44:14
question; how do you gus stay within rpm limits by just installing a spring? I have tried that it goes crazy at hi idle dont want to stand to close how do you get it past the tech boys?
ChadS
02-20-2004 17:12:10
 Re: Re: Re: Re: Re: GOVENOR-CHADS in reply to junkyard dog, 02-20-2004 15:05:48
The adjustment bolt inside the governor, the spring will get you to 2600, you can still back it down to 10% or where ever you set rpm. Chad
