Re: need more info
fellow puller
02-05-2005 18:17:14
You can start by draining the rearend down to the point that there is justb enough oil there to bath the drive gears.If you choose 9 bolt wheels would cut down tremendously,you can also use weld on adapters and then cut the axle stubs off.Aluminum bolster and 4 or5 bolt wheels.try some of those ideas to start.
