Restoration & Repair Tips Board
Re: Oversize piston rings
jdemaris
04-06-2006 06:17:40
If done right, it will work fine. We used to rebuild pistons - recut the grooves to oversize, knurl the skirts, etc. Then parts got cheap, and labor expensive, and it wasn't worth it anymore. Now ?? It is just as important to repair the side clearance, i.e. the ring-grooves on the pistons. It is just as important if not more than the ring-diameter and end-gap. Check if with a feeler gauge. Hasting sells repair shims and they are cheap. Requires having someone recut the ring grooves in the pistons. I just had four pistons cut and it cost me $30 total. I don't know why you picked the .060" oversize number - you should stick as close as possible to the original. If standard bore now, and worn, trying getting some .002" oversize, or .010". I've installed slightly oversize rings on many tractors and it worked fine. I wouldn't do it on a diesel, and I wouldn't do it on a machine I was working every day. Hastings will sell you individual rings which is a pretty good deal. So, you can pick and choose.
