Restoration & Repair Tips Board
Leak on Oil Pan
Peter P. Cheek
04-11-2006 18:32:55
I have a farmall 1100 with a C123 engine that I completely overhauled. The tractor runs well only I can't stop the oil pan from leaking oil. It's not terribly bad, just annoying. I put a new pan gasket ,the gasket type and they weren't overtightened, any clue as to what I could try.
souNdguy
04-12-2006 13:31:42
 Re: Leak on Oil Pan in reply to Peter P. Cheek, 04-11-2006 18:32:55
Help us 'non' mind readers out. where is it leaking from.. a bolt? the mating flange? a crack? the plug? porous cast/flaw?
Not a pressurized sump. if it is a flange leak.. look for flaws inthe flange, gouges.. etc.. or a piece of old gasket.. Gouges can be filled with jbweld.. then sanded smooth. i generally don't like gasket goop.. but for a non pressurized sump.. it will be ok when used to seal an otherwise proper gasket that is finicky.
Cracks and flaws inthe cast can be sealed by removing pan.. clean with carb cleaner.. either braze or use jb weld anfter burnign off oil residue with a propane torch
leaky bolts / studs int he block can be sealed by pulling the bolt or stud and using appropriate pucky on the threads and then reinserting. Double nutting pulls most 'leaky' studs easilly..
Soundguy
Randy_NE
04-12-2006 11:02:52
I did a search for "leaking oil pan" Try this for a start.
