Restoration & Repair Tips Board
Re: rear light for 435 doesn't work
blueboy
04-30-2006 18:05:41
Bguy
Thanks for the reply. Would the light housing show to be hot? When I grounded the tester and touched the housing the tester lit up indicating it was hot. If I remember I grounded the light by touching the ground on the battery and it sparked pretty good.
I thought too it wasn't grounded because of the new paint and will try to scrape off some to get a good ground, but is it normal then the light housing and bolt would be hot? I appologize for not being up on the electrical aspect of this situation, but figured I would ask for help rather first rather than spend money buying a new light when the present light might be good
Thanks for your response and help.
Dan
Bguy
05-01-2006 10:57:53
 Re: rear light for 435 doesn't work in reply to blueboy, 04-30-2006 18:05:41
I don"t know if it is hot or not. It"s been awhile since I worked on one of these but I"ll check mine tonight and report back.
Bguy
05-01-2006 19:15:41
 Re: rear light for 435 doesn't work in reply to Bguy, 05-01-2006 10:57:53
I checked mine this evening and the housing is not hot. Sounds like you have a short somewhere inside the can.
blueboy
05-04-2006 20:50:01
 Re: rear light for 435 doesn't work in reply to Bguy, 05-01-2006 19:15:41
I sanded a couple of places to create a good ground and low and behold it works! Thanks to everyone for their help! Really is appreciated!
Dan
