Restoration & Repair Tips Board
Misunderstanding
Dick L
01-13-2008 15:03:37
There is a lot of misunderstanding of the reason for using aluminum paint on head gaskets.
The using of aluminum paint on head gaskets is not used as a sealer. Aluminum paint is used to keep the gasket from sticking to the head or block so it can be reused. That practice started back before my time. I never intend to reuse head gaskets although I have a coupla times.
The only gaskets that I have used a dope on is the metal clad gaskets in over 50 years. Dope is not needed on fiber gaskets. It does not hurt a thing, use it if it makes you feel better but it will not help and is not needed.
Bob
01-13-2008 22:27:13
 Re: Misunderstanding in reply to Dick L, 01-13-2008 15:03:37
Where's the missunderstanding? Aluminum paint DOES help metal headgaskets to seal, especially to avoid having coolant "weep" out between the head and gasket, or gasket and block.
Dick Lemmon
01-14-2008 13:16:21
 Re: Misunderstanding in reply to Bob, 01-13-2008 22:27:13
Misinformation plain and simple.
Like I said if it makes you feel good using it use it. It sure won't hurt anything and when you remove the head the gasket it won't be stuck fast. Like using anti seize.
