Restoration & Repair Tips Board
Re: Clutch finger adjustment SOLVED!
Edpap
04-24-2008 20:46:20
Hello Pete,
I would not run that tractor like that, you will wreck your new clutch. I would adjust your lincage so that when the pedal is at it lower stop the clutch is disengaged. I don't know what the spec for free play is on that tractor but there must be some. I think your right the only way the clutch will engage is if the fingers are contacting the clutch disc if that is happening you might break a finger or rip the springs out of the disc. I can assure that the tractor was made to work that way. and it should be fixed.
Good Luck Ed
Pete M.
04-25-2008 02:53:02
 Re: Clutch finger adjustment SOLVED! in reply to Edpap, 04-24-2008 20:46:20
I agree. As I've posted as a reply to another poster, the previous owners removed things from the machine and I've been spending the last year finding that out the hard way. The foot rests used on the farm tractor version are missing and I'm assuming the stop was on them. I'll be fixing that problem this weekend. What I'd give for a couple of good images of what this machine should have on it.
Pete M.
04-25-2008 06:49:09
 Re: Clutch finger adjustment SOLVED! in reply to Pete M., 04-25-2008 02:53:02
It also turns out as I should have expected, the manual I've been using is once again dead wrong. When I bought this machine the linkage for the clutch had the pin in the rear hole. The manual I have also shows the pin in the rear hole and claims that's the setup for the late 4 and 5 spd tractors. I reset the pin to the front hole and the clutch works fine with no overpush on the fingers. This manual is going to get filed in the circular filing cabinet.
