Restoration & Repair Tips Board
Re: tractor labors really hard when the pto is on
glennster
04-25-2008 12:54:12
could be a bearing is gone on the pto shaft, or bent shaft causing it to bind. with the engine off on the tractor and the pto out of gear, try spinning the pto shaft by hand, you should be able to turn the shaft by hand, there will be some resistance. if you cannot turn it at all, something is going on inside the pto, bearing ect.
