Restoration & Repair Tips Board
Re: NAA carb
John K
12-25-2003 07:01:15
I work on Lincolin welders, on their updraft carbs they al so have a a brass plug in the bottom. The plug has a dense cintered screen in the center. I have assumed that was for fuel to drain out if for any reason the float was not shutting off the fuel supply. I use carb cleaner to make sure it is clean, when clean you can hardly blow through it. I can not see through it. It must have some sort of screen or else you will be getting contaminates into the engine. Hope this helps.
