Restoration & Repair Tips Board
Re: Electrolysis--- My first Try./???
Josh (Holt T-35
08-04-2004 22:25:25
I have been playing with the same process with good results. I cleaned up a set of Kelsey-Hayes wheels with no effort at all. You might not have enough current for that much surface area. Try just letting one corner of the part be submerged and see if you get bubbles. The bubbles shoud start showing as soon as power is applied. Even if you are overloading the charger it should put out for a short time. Be sure that the work is not touching the scrap that is connected tothe positive and that the scrap is steel and not galvanized, but fairly clean steel. I don't use a battery charger. I use a 12V 40 Amp power supply from a General Electric 2 way radio. It can handle large cueents for long periods. Hope this helps. I am a first timer with this process also. Just been playing with it for a week or so. Josh
