Restoration & Repair Tips Board
go to JD garden tractor
Coloken
09-15-2004 06:00:19
This is one you might do better on at the JD garden tractor place. They used to be a good place. That varactor is a touchey thing to get adjusted just right. Right belt, right spaceing etc. Problem with mine was wear on shafts so that the pieces did not slide like they were supposed to. Wish they had a greese fitting on the slide. I helped mine by adding another spring to increase spring pull.
