Restoration & Repair Tips Board
Re: naa transmission stuck in 2 gears
Dan
07-21-2005 07:42:41
This rail slides back and forth through openings in the tranny housing on both ends towards the front and the back. The openings are blind so as to not leak tranny fluid from between the rails. The front opening is cast into the tranny housing, and the rear opening is cast into the HYDRAULIC housing and is sealed by the gasket that is in between the tranny and hydraulic housings. It is possible that either debris or part of this gasket got down into this blind hole and is not letting the rail slide all the way in, or crud has built up around the outside of the rail in the area that slides into the opening and is keeping the rail from sliding in all the way as well. Unfortunately, the only way to get to these holes is to split the tractor between the tranny and hydraulic sections. This split is actually very easy and quick, just make sure you have a replacement gasket on hand before doing it so you can put it back together.
Investigate some more and let us know.
Good luck,
Dan
