Stationary Engines Discussion Forum
Re: Re: Re: Briggs and Stratton carb problem
Jim W.
04-04-2004 15:10:00
I have a go kart and I am experiencing the same problem. I replaced the diaphram and have inspected and cleaned the fuel tank suction tube. And still the only way to keep the engine running is to keep squirting gas into the intake. Any suggestions?
Tice Brashear
05-16-2005 16:52:05
 Re: Re: Re: Re: Briggs and Stratton carb problem in reply to Jim W., 04-04-2004 15:10:00
I had the same problem. I have a pulsa jet carb that was the source of the problem. I replaced the diaphragm but still had the same result. I finally traced the problem to the shorter of the two fuel uptake stacks. It has a pin hole in the bottom of the uptake that was clogged. When I cleaned it with a wire, it took off. Try this link if you need a description of what to look for: http://www.compgoparts.com/technical/001/BriggsCarburetor.asp
Good luck
Danno
05-03-2005 18:53:03
Hey has anyone figured out what the problem is with these Briggs,I have the same I"ve cleaned the carb,new diaphram etc. The only way it trys to run is with your hand covering the carb choking it. The local shop tells me to replace the carb and the tank. I would like to find the solution rather than replace everything under the sun. Any help would be great.
Thanks,Danny
