Tractor Talk Discussion Forum
Not worried?
jdemaris
01-17-2008 14:53:09
There IS certainly truth to it if you believe strict test data. If low lube in a fuel shortens the life of one of your injection pumps by 20% or 30% - I doubt you'd ever know the difference.
There has been a lot of testing and it boils down to this.
I'm going to stick to the number used when testing for wear-scars of internal metal parts. This is usually the HFFR test ISO 12156.
Mechancial fuel injection systems with fuel-lubricated injection pumps need a fuel that tests at less than "400,000" to last as designed.
The average high-sulfur diesel was tested at 396,400 with the HFRR test at 60 degrees C.
The average ULSD diesel tests at 666,650 which absolutely WILL make pumps wear prematurely.
Now - ULSD is supposed to have lube additives put in to bring it up to around 500,000.
So, as it stands - if everyone does the job right - and the additives get put in by everyone as they should - then it should be just barely adequate for older rotary pumps.
In short - diesel naturally had the lube qualities the old systems need - and now it does not and needs additives.
Personally, I'm not that trusting all of this done properly, i.e. monitored and enforced since it's all still relatively new.
I see putting lube back in the ULSD as a cheap investment. I use two-stroke oil added at a 200 to 1 ratio and it's been tested to bring the wear-scar # down by 160 microns -which is a lot. It adds more lube for less money then most commerical additives - but the two-stroke oil is not 2007 and newer emission's compliant.
