Tractor Talk Discussion Forum
Re: Penetrating oil
rustyfarmall
09-02-2003 07:06:14
Actually, I have had pretty good luck using a mixture of diesel fuel and brake fluid, if I need a bit more lubricating ability, just add a little motor oil to the mix.
Indydirtfarmer
09-02-2003 08:04:27
 Re: Re: Penetrating oil in reply to rustyfarmall, 09-02-2003 07:06:14
Brake fluid, diesel fuel, and automatic transmision fluid (Dextron if it makes any difference)
Chris-se-ILL
09-03-2003 09:42:56
 Re: Re: Re: Penetrating oil in reply to Indydirtfarmer, 09-02-2003 08:04:27
Just a note, Indy... That brakefluid will peel or discolor painted areas! Be careful where you use it!
Clint @ MD
09-02-2003 09:32:10
Indy- What ratio are you using for this mixture? I'd like to try it sometime.
Thanks.
