Tractor Talk Discussion Forum
Re: Favorite plowing set up
Larry NE IL
05-06-2005 20:17:38
Oliver 1950T with 5 18's
MPK
05-06-2005 21:03:35
 Re: Favorite plowing set up in reply to Larry NE IL, 05-06-2005 20:17:38
JD 4430 with DMI 5 bottom variable width plow with 16 inch bottoms. Adjustable from 12 to 22 inch bottoms. Mostly used it on 18 to 20 inch. For plowing the headlands set it on 14 to 16 inch. This plow would go through anything, seems like it had about 40 inches clearance under the frame.
Drill
05-06-2005 20:55:31
I'm pulling and IH 5/16 with a Massey 2705 with duals on. Have the hitch swung over as far as it will go, so tractor stays up on the unplowed land. I get better traction and use less fuel.
Harley
05-06-2005 21:15:41
 Re: Favorite plowing set up in reply to Drill, 05-06-2005 20:55:31
560 with 291 706 gas engine pulling 4/14 semi-mounted in Iowa black dirt. Made the old girl get down and beller. Harley
Jerry Cent. Mi.
05-07-2005 06:15:56
 Re: Favorite plowing set up in reply to Harley, 05-06-2005 21:15:41
I haven't seen anyone plow around here in years. Most farmer around here just spike tooth. I do plow with my old tractor friends with my Furgeson 20 and two 14's. Jerry
