Tractor Talk Discussion Forum
Re: Allan in NE
Dr.EVIL
04-03-2006 10:47:01
Allan - 18.4 X 34's were the option. Not 18.4 X 38's. The parts were there to even put 20.8 X 38's on them but that wasn't available.
Allan In NE
04-03-2006 10:51:03
 Re: Allan in NE in reply to Dr.EVIL, 04-03-2006 10:47:01
Aw Ha!
That's why I have to gear the old pig down. She just walks way too fast. 2nd gear feels like 3rd ought to. :>(
Always did think those tires were way too darned big.
Thanks Pard,
Allan
hayray
04-04-2006 04:25:45
 Re: Allan in NE in reply to Allan In NE, 04-03-2006 10:51:03
Allen,
I must have mis-understood your post last week when we were conversing bout the cultimulcher, I thought you did not mould board?
Last time I tried to disk before I plowed it created a real mess with trash build up. However, when I used a IH 710 5 bottom, that has a lot of clearence and long distance between bottoms and handled trash real well. Would a chisle plow work for what you do, that is all I use now as far as digging up roots, but if you want to save moisture and summer fallow why not just use round-up and a disk?
Ray
Allan In NE
04-04-2006 05:18:47
 Re: Allan in NE in reply to hayray, 04-04-2006 04:25:45
Hi Ray,
Appears pretty "flip-floopy" don't it? :>)
Normally, and if I could have been lucky enough to have gotten this patch fall-plowed, I wouldn't even be thinking about it; I'd just run the packer over it and be done with it.
Without publicly going into details tho, there were some issues with the purchase agreement and I wasn't able to plow this field until this spring because the prior operator's hay stacks didn't get removed until just a few weeks ago.
So, here I set with a "slabby" mess and it looks like the disc is going to be the only option if I wanna get it cut up and worked down this summer.
I've plowed a lot of sod, but this root infested, cattle tromped pasture is the worst I've ever ran into. So, I'm gonna give your method a trial and hope beyond hope that I luck out and get a rain on it to help melt it down before September.
Allan
Quebec Red
04-03-2006 12:25:30
Went all through the trans and diffy of a F656 that I bought that had 18.4s38s. When I was finished, that tractor had 6.50x16s and 15.5x38s making her level. Cranked the Roosa to 2400, and got my highway hot rod speed back!!!!!, and with those tires, she kept it there. With the 18.4x38s, even a fart in the wrong way would slow it down. Pretty much redid the tractor from flywheel back. Mucha $$$. Luckily, when I bought it,I had a good idea what was needed, and priced accordingly. Still was stupid of the previous owner to willfully set himself up. Now that you can pull in 3rd with Mr. Big Stick reaching for the radiator, you will be at the limit limit ( I know that there are two limit words....) of what you may pull, change the transmission oil and filter after working this spring to remove the rust and varnish and other crap that will have come off the gears etc. and are in suspension. Keep us informed...QR..
