Tractor Talk Discussion Forum
Re: Cracked Block
the tractor vet
07-31-2006 21:38:12
I have had good luck with K&R block sealer but you have to drain and flush the system with a cleaner a couple times remove the thermostat fill with clean water pour the stuff in a hot engine and run for about thirty min. then drain and let set for 24 hours then if it worked you can refill with antifreeze and good to go.
