Tractor Talk Discussion Forum
Re: I Need Your Opinion
mjbrown
09-15-2006 15:52:31
Was this seeded this year? If so let it go so it will have good root reserves. The top growth that the frost kills will help hold snow cover in the winter to help shelter the crowns. I think I would do this even if it is an older seeding unless you plan to rotate it out to something else. I think if you cut it you will pay for it next year.
steveormary
09-15-2006 16:24:19
 Re: I Need Your Opinion in reply to mjbrown, 09-15-2006 15:52:31
Allan, I think I could agree with those that say leave it. It will greatly improve your first cutting for next year. If you need feed I think you ccan pasture it after the ground is froze. Then in the spring go over the field with a spike tooth harrow. More improvement for the first cutting and it smooths the field some.
Good luck. steveormary
