Tractor Talk Discussion Forum
Re: Propane Tractor Fueling
John A.j
10-14-2006 06:22:53
Andrea, Let put this in simple easy to understandabe form.
LP in your nurse tank will....move.. via a hose (no pump) from an area of High Concentration and Pressure ....to an area.... of Low Concentration and Low Pressure.
Simply hook up the fill hose, Open main valves. Then Open the (Bleeder valve) to drop the pressure and concentration in the tank, the LP will move through the hose to the tank being filled. When the Bleeder valves runs liquid LP ...shut off the Bleeder and main valves. remove the hose and Off you Goooo. Hope this helps.
Later,
John A.
Andrea
10-14-2006 07:23:42
 Re: Propane Tractor Fueling in reply to John A.j, 10-14-2006 06:22:53
Thanks so much for all of your quick replies!! I have been calling around ALL WEEK trying to get a straight answer and still had to post here.
It seems everyone is in agreement, so I better get started calling around to find someone to put the line on!
Thanks again! You guys are great!
Andrea
Allan In NE
10-14-2006 07:29:43
 Re: Propane Tractor Fueling in reply to Andrea, 10-14-2006 07:23:42
Talk to the fella who fills your tank.
If he doesn't have a clue as to what you are needing, get a new supplier. :>)
Allan
