Tractor Talk Discussion Forum
1952 Farmall - welding shifter
JBW
12-10-2006 13:39:05
First - thank you to "Don LC, IaGary and Allan in NE" for your suggestions for our Farmall that was stuck in gear on our driveway (see 12/3/06 post). Thankfully we had just enough room to drive around it until it was moved.
Now that it is back at the top of the driveway, I want to repair the shifter so this doesn't happen again (at least for awhile) - any tips on welding the end? Am I adding weld to the very end (making it longer) or to the sides of the tip (making it wider)? How much? Any suggestions on the best rod to use? Any thoughts are welcome.
neblinc
12-11-2006 05:45:53
 Re: 1952 Farmall - welding shifter in reply to JBW, 12-10-2006 13:39:05
Here is a pic from Cowman on what it should look like.
Randy
JBW
12-11-2006 08:29:57
 Re: 1952 Farmall - welding shifter in reply to neblinc, 12-11-2006 05:45:53
Thanks so much - the picture is great!
Hugh MacKay
12-11-2006 03:45:56
JWB: I doubt if you need to make it longer, they don't wear on the bottom. I've rebuilt 7-10 of these going back to the late 60. Shape it so it just neatly fits into one of the notches of the shifter rails. Start with in full size of one of those notches and grind until it shifts smoothly. When new that end of shift lever was a perfect rectangle with very slightly rounded corners. If you make it much longer it will rub on bottom and be hard to shift anywhere. I've been around these old Farmalls close to 50 years, never seen a shift lever rounded on the bottom end yet. Look at the wear, not hard to see where it's worn.
IaGary
12-10-2006 15:39:27
Thats what we are here for:to help you and someday you will return the favor,if not to me someone else.
Was it in two gears?
Gary
JBW
12-10-2006 16:32:45
 Re: 1952 Farmall - welding shifter in reply to IaGary, 12-10-2006 15:39:27
Yes - it was in two gears ... ended up jacking up the right side on the drawbar and while one person rocked the wheel the other used a screwdriver and pushed the gears back in line.
TomH in PA
12-10-2006 14:46:34
You'll want to make it longer. It should be round at the bottom, your's is probably squared off.
JBW
12-10-2006 14:57:05
 Re: 1952 Farmall - welding shifter in reply to TomH in PA, 12-10-2006 14:46:34
It is definitely squared off now - the slot it sits in is rectangular and flat - are you sure it should be rounded at the tip?
135 Fan
12-10-2006 14:32:11
7018 would probably be the best rod to weld it, however try to find out what it is made out of. It's probably steel or cast steel. If it is 7018 will work. Dave
Don L C
12-10-2006 14:19:56
JBW ---
Youll just hawe to look at it and try to decide where it is wore away.... I traced mine on paper and took measurements before starting..... if you dont you wont know where you started.....if I rember I added 1/8" to the length and adout 1/16" to each side..... grind it flat and smooth.....that may not be perfect but it should work for a long time.....maybe some one has a new one they could post measurements for the rest of us..... good luck Don
