Tractor Talk Discussion Forum
Re: 100 plus HP loader tractor
Hugh MacKay
03-22-2007 19:35:47
B&D: I don't think I'd too awfully concerned about Gary's setup as it applies to danger. I used to pull highway trailers loaded with grain behind my 1066, no loader mind you but with duals. I didn't go racing, but I had no trouble stopping 25 ton on level ground.
Why just yesterday I was up your way, on the outskirts of Harriston, I caught up with a CaseIH 150+ hp 4x4 and duals, and behind him a fully functional Super B train. He had full tail lights, marker lights, signal lights and 4 way, plus he had fully operational air brakes. He was loaded full height, length and width with large square bales. He came to a hill, didn't slow him down a bit until he came too a stop sign. Once he had the right away, it was left turn from starting on the upgrade. He cleared the intersection as fast as any highway tractor would.
If I met Gary on a down grade and he had enough 4 wheel wagons for 40 round bales, I'm certain I wouldn't be alarmed. These tractors have quite bit of ability to handle big loads.
A 1066 or 86 with duals, 20' disk behind, at full throttle in high gear, on dry black top, has the ability to stop in 4'. I know it did cause some smart a$$ cop some grief, that decided to follow me on a dark night with high beam lights on. We had some harsh words, but he did rear end me. Didn't hurt the disk, but his cruiser didn't look quite the same. There was no point in me driving further as I couldn't see anything with those high beams behind me.
buickanddeere
03-23-2007 10:15:34
 Re: 100 plus HP loader tractor in reply to Hugh MacKay, 03-22-2007 19:35:47
I enjoyed the story about the local "super trouper". Most are alright guys but some do need a reality check. A couple of times I've had somebody ride my car bumper so close I couldn't see their head lights. I was doing 10K over the limit and wasn't going to speed up to 15+ over just in case it was a crooked cop behind. Sure enough both times it was an opp cruiser. Having a “big black dog” run a cross the road in front and having to lock the brakes was appealing. However previously I had “locked horns” with somebody who afterwards turned out to be an off duty cop. It worked better for him in the courts than it did for myself. At 1st glance I figured both of Gary's hay racks as being four wheeled. The 1st unit being a two wheeled trailed applying a ton or two of weight on the drawbar changed the weight equation from being potentially dangerous to being acceptable if careful. The land is flatter here but still the same greasy clay as at home. On the hills there it isn't safe to haul a heavy load with a lightweight machine. I had 24 4'x5' round bales on the wagon and one on the loader bucket of the 2WD JD 2355.It's carrying a full load liquid ballast in the 18.4x30's and three cast weights per side. She began to get squirrelly on a hill and dropping that bale off the front became a priority. You can always make another trip to the field for an extra load faster than cleaning up a wreck. Hugh, you may have well driven another ¾ hour west. I would have opened a couple of cold ones and showed the fancy birds. Could have even sent you home with a dozen blue/green chicken eggs from the exotic breeds. I’m actually wondering if we know of each other from one of the Ag organizations around here?
Hugh Mackay
03-23-2007 15:13:14
 Re: 100 plus HP loader tractor in reply to buickanddeere, 03-23-2007 10:15:34
Glen: I'm quite certain that is correct. You mentioned making that extra trip to the field, reminded me of an old codger back in my hometown in Nova Scotia. Lawerence was known to be a very gruff but gentle and mild mannered sort of guy. The type to never get rough with his equipment. Folks also liked to tease him as he never married until he was 50. He married an English tracher that probably never made a grammer mistake in her life. I had her for a teacher in high school. Lawerence was a good target.
One day I was at the welding shop, and Lawerence came in with the front end off his 8N, broken in two at the pivot point. The welding shop owner just couldn't resist and said, "Lawerence how did you ever do that." He added a whole lot more I can't remember. Lawerence said, "Gerald, you know how it happens, a fool tries to bring the last two loads of wood home in one load."
I don't believe we've met, you and I exchanged some e mails about three years ago, something about tractors. I have your e address written down, I actually had Glen written in there as well.
buickanddeere
03-23-2007 20:18:07
 Re: 100 plus HP loader tractor in reply to Hugh Mackay, 03-23-2007 15:13:14
Just noticed I can't do math after night shifts. It was 14 bales on the wagon,not 24. Sometime after driving all way the west you can go without getting wet in Lake Huron. Let me know and drop by.
