Tractor Talk Discussion Forum
Re: PHOTO - the dust making machine
georgeky
05-02-2007 05:19:59
Hi David, here in Kentucky, we call that a drag. Some folks have them made like that one, and others like myself have them made from rail road ties held together with large bolts and old disk harrow spacer spools.
Allan In NE
05-02-2007 05:35:29
 Re: PHOTO - the dust making machine in reply to georgeky, 05-02-2007 05:19:59
Yep,
Here that would be a yard drag.
However, I can certainly understand what they are trying to do. Kinda built along the lines of a field float once used for flood irrigation.
Allan
georgeky
05-02-2007 11:31:18
 Re: PHOTO - the dust making machine in reply to Allan In NE, 05-02-2007 05:35:29
Allen, what part of Nebraska are you in? I use to hunt pheasants in the south east corner. Over around Shickley,Beatrice. Also hunted Quail down on the Little Blue River.
georgeky
05-02-2007 06:06:23
Allen here we use them on plowed ground for the same reasons that David stated. Especially on sod ground that sometimes doesn't turn over good. This pulled over it in the same direction the plow traveled will turn it on over and fill in all the low places. It really makes ground work good if done very early in season and left to lay for a while. Then the disk will do a fine job on the ground. I rotate crops and plow a lot of sod here for tobacco.
Allan In NE
05-02-2007 06:18:22
 Re: PHOTO - the dust making machine in reply to georgeky, 05-02-2007 06:06:23
I hate running a disc in plowed ground, but agree it's gotta be done sometimes due to the "belting/roping" of the darned sod. Fact is, I gotta do just that here in a day or two; not looking forward to it at all. :>(
Normally, I just use the packer and plant.
Allan
third party image
georgeky
05-02-2007 10:40:23
 Re: PHOTO - the dust making machine in reply to Allan In NE, 05-02-2007 06:18:22
I wish I had some big wide open fields like that. Now I am wanting to move west. 4 or 5 old farmalls would look good following behind that one. Or even my 666.
dds-inc
05-02-2007 07:49:07
Allan, Looks like you could use slightly wider front tires for that job. Nothing like falling into rut after rut.
Allan In NE
05-02-2007 07:58:03
 Re: PHOTO - the dust making machine in reply to dds-inc, 05-02-2007 07:49:07
I don't have ruts. :>)
Allan
