Crawlers, Dozers, Loaders & Backhoes Discussion Board
Re: New Holland L555 skidsteer, tipped wheel jamm
Posted by jhill on January 16, 2005 at 20:45:58 from (69.179.59.227):
In Reply to: Re: New Holland L555 skidsteer, tipped wheel jamm posted by LK on January 16, 2005 at 18:40:40:
I have a JD 5575 which is about the same machine. The hub assembly bolts to the skid steer frame. The wheels are driven by chains from the hydraulic motor. If the wheel is crooked either the frame is bent or the hub assembly is damaged. The chain is probably binding and not allowing the wheel to turn. You should be able to tell which is damaged by taking off the wheel. You are are going to have to straighten out the wheel to fix it.
Post a Followup
Subject:
